Old 11-10-2007, 10:20 PM   #1
mkiiisupra
Default Valve Assy, Air Control Broken~ Help
Need help with a problem i found while installing a kit from hose techniques
17630-70010 Valve Assy, Air Control http://www.cygnusx1.net/Supra/Librar...rts/17630.aspx
I found that one of the nozzle on this piece is broken off as well as the vacuum line currently being disconnected from the other nozzle on it.
So far this part seems to be about 175$......
But i have no idea about how to get to it to remove it.... any ideas?
Old 11-10-2007, 10:20 PM   #2
mkiiisupra
oh also, what kind of problems does this not being connected cuase
Old 11-11-2007, 12:05 AM   #3
mrnickleye
mrnickleye's Avatar
Follow the vacuum line over to the intake manifold, and cap it off. This valve is mounted on the power steering pump. It's function is to raise the idle slightly when you are idling, and turning the steering wheels. Like in a parking lot.
You can live without it.
be sure to plug the hole in the air intake on the intake 3" hose to prevent dirt from entering your engine thru the intake.
Old 11-11-2007, 01:25 AM   #4
mkiiisupra
So cap it off at the hose 17343B ? is that the only place i need to cap it at?
http://www.cygnusx1.net/Supra/TechTi.../vacuum_2h.gif
Thanks
Old 11-11-2007, 03:49 AM   #5
mkiiisupra
Bottom of Accordion Hose to Power Steering Idle up connection.
26.0
6.0
is that the other one u want me to cap off??
i have that line hooked up, but since that other section is busted i should close it off? and that wont interfere with any other parts of the vacuum line?
Old 11-11-2007, 11:25 PM   #6
mrnickleye
mrnickleye's Avatar
Thanks
YES. That pipe. Just put a vacuum plug on it. The other, on the accordian hose, needs capping too, so dirt won't enter the engine.
Old 11-12-2007, 03:00 AM   #7
mkiiisupra
Refering to the vacuum line on the bottom of the accordian hose. Just wondering how this ties into that system. Curious is all
Thanks alot for the clerification
Old 11-12-2007, 10:50 PM   #8
mkiiisupra
coming from the bottom of the accordian hose.
So i am guessing then, that this vacuum line is not routed properly? or is it?
If not what plugs into the metal line that comes out of the bottom of the charcoal canister
Air Control Valve nickvash0104 MKIII Supra 0 03-07-2006 06:26 PM
