mk3 wont pass 40 mph??
i just bought a 1987 mk3 auto turbo. Car take off fine until it hits around 40mph, start bogging and struggling. My buddy says its a ECU problem, too much fuel maybe? cuz its blows out black smoke when I take off. plz help me I'm new to supras
have you checked the sparkplugs? coilpack maybe sum of them are fouled and youre not burning the fuel anymore jus a few thoughts |
my car just had a full tune up
Any check engine codes?
BTW the ECU should be one of the last things you check IMO. |
yea got it checked. its not the right code
Too rich running will cause the cat converter to fail. Perhaps you have a plugged exhaust, which will do what your car does.
I don't think your ride would roll if you had an ecu problem.
My car will start and idle but it sounds like a loping v8. The timing is dead on balls acurate 100% no doubt. I replaced the afm. Then replaced it again. My ecu has to be fragged. Upon test driving I blew a coolant line ond it fogged the cab through the air vents and it's been absolute filth sinse that day. Does anyone know anyone trust worthy to send this thing to for service. Or even better does any one have a 90/91/92 manual tranny ecu they know works and wants to sell?? |
Supramacist is it N/A or Turbo?
Non turbo.
Wich is the problem. Ecu's for turbo's are everywhere. |
4o problem
i would say its your cat. i would start there. just unbolt it drive around the block if it goes passed 40 then thats it,, easy fix straight pipe done problem. anyways my opoin. good luck
| All times are GMT. The time now is 07:38 PM. |
