Old 11-03-2007, 03:29 AM   #11
west_side_supra
west_side_supra's Avatar
3 screws :P
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 11-03-2007, 04:22 AM   #12
cyanide-is-a-way-out
cyanide-is-a-way-out is on a distinguished road
i unscrewed the whole back thing fro the metal housing when i cleaned it
cyanide-is-a-way-out is offline   Reply With Quote
Old 11-03-2007, 06:17 AM   #13
CyFi6
im talkin about the screws that are on either side of the connector, some people cant figure out how to remove the connector so they unscrew the whole thing and out comes a bunch of wires and it messes it all up
Old 11-03-2007, 06:37 AM   #14
jfunez
jfunez's Avatar
get an air gun with compressed air and carefully blow the sensor with air...be very carefull as too much air pressure will harm it....blow specially in the small oriffice... I did the same thing and it worked great afterwards.....
there is fluid still trapped in the small holes of the sensor.....
New here, quick question on possible lean issue adamsbomb MKIII Supra 6 02-13-2007 04:42 PM
Quick release hub adapter!? 88Supraboy MKIII Supra 4 03-04-2006 04:10 PM
Quick release hub adapter 88Supraboy Non-Generation Specific Questions 0 03-02-2006 01:55 PM
new to forums... some quick Q's gfx MKIII Supra 3 10-12-2005 01:54 PM
