Old 10-29-2007, 11:04 PM   #1
MkIIImge
MkIIImge is on a distinguished road
Unhappy 3000rpm
So, mostly in 2nd and 5th gear when between 2800 and 3100 rpm my car shakes like when your are in high gear at 1000 rpm, like being starved of air, When cruizing on the Highway at 60-68ish its always rumbeling and its really anoying, any ideas?
and NO CELs
MkIIImge is offline   Reply With Quote
Old 10-30-2007, 03:20 AM   #2
jfunez
jfunez's Avatar
possible bad mass air flow sensor...or boost leak if its a turbo...
check the plastic intercooler elbow in the right inner fender..they tend to break open just a crack...
Old 10-30-2007, 05:20 AM   #3
Supra2NR
Supra2NR's Avatar
If its the mass air it wouldn't even go pass 2000 rpm
How slow do you drive
At higher gears?
I mean if you go too low
Wouldn't the car stall?
Maybe that's why its shaking?
Old 10-30-2007, 06:22 AM   #4
CyFi6
check your timeing, over advanced could cause it to detonate and feel like its shakeing like that. Also test the throttle position sensor
Old 10-30-2007, 04:54 PM   #5
MkIIImge
No its not a turbo, and when running at 3000 rpm it Feels like when your in too high gear for the RpM.
im talking Like 5th gear arround 3000 rpm is when its shaking and 2nd gear around 3000 rpm
Old 10-31-2007, 12:57 AM   #6
Check the drive shaft, u-joints, center support bearings.
Check engine light goes on around 3000rpm. Gunnar MKIII Supra 7 12-30-2007 10:02 PM
