Old 10-23-2007, 11:35 PM   #1
west_side_supra
west_side_supra's Avatar
Default pressure sensor?
ok i have to ask, since i'm relocating all my electrical in my engine bay, i'm getting rid of the cruise control, i also noticed a sensor called the turbo pressure sensor assembly, what the hell is this, and where can i reroute the vacuum source for it? currently it is hooked up to the cruise control? and do i even need the damn thing
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 10-24-2007, 11:45 PM   #2
west_side_supra
i have already searched TSRM for anything on this, it just tells me the wire colors, and how to install it. but what does the thing do?
fidenza cam gears
Old 10-25-2007, 12:26 AM   #3
Supra2NR
Supra2NR's Avatar
well i believe its on the firewall side of the intake manifold
it sends the signal to the boost gauge
i replaced mine with a pipe fitting
since i like manual gauges better
Old 10-25-2007, 05:23 PM   #4
west_side_supra
well i got some glow shift gauges to replace the other boost gauge, EGT, and oil pressure, AFR guages also.
another thing i was trying to find is a area to rout my wires through the firewall some how
fidenza cam gears
oil pressure sensor sundevil1 MKIII Supra 2 12-06-2008 08:21 PM
Whats The Thread on The Oil Pressure Sensor? Chambers MKIII Supra 2 01-22-2008 02:24 PM
oil pressure sensor justin1642 MKIII Supra 20 09-27-2007 09:23 PM
