Closed Thread
Old 04-30-2007, 04:27 PM   #11
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
Default hose
autozone sells vacuum hose like the blue kit shown above for 15.00 like he said it is cheap and you do hafto cut but if you take one hose off at a time its not hard.. also you might want to zip tie the ends so they dont slide off.
My 1989 toyota supra mods:83.5 mm bore, ARP main studs, ARP rod bolts,rings, Cometic .060" headgasket, ARP head Studs, Ferra 1 mm oversized valves, port work, Rc 550cc injectors, Walbro 255hp
Turbo: 1.15 A/R T4 twin Scroll turbin - journal .60 A/R compressor, Hallman Pro MBC, Turbo XS Blow-off Valve, 50mm wastegate, hks fcd
Intercooler: 32x12x3 core, 3 inch piping, with clampco t-bolt clamps
Exhaust:Exhaust manifold T4 twin scroll,2JZ 3 inch downpipe Fabed up to fit, Mandrell bent 3in back
Supra_87_mk3 is offline
Old 08-13-2007, 01:41 AM   #12
http://www.geocities.com/btwilson86/..._Diagram_A.gif
mrnickleye is offline
Closed Thread
HTML code is On
Hose Diagrams illusion408 Non-Generation Specific Questions 3 07-07-2005 02:54 AM
