Old 02-16-2012, 03:09 AM   #1
2genfun
2genfun is on a distinguished road
Default Lexus AFM
quick question...my turbo mk3 was running fine, completely stock. i put a lexus afm on it and now it breaks up while driving normal, and seems to have a hard time idling.
88 targa. H&R springs, koni adustable shocks, 18" wheels, d&s rotors, goodrich brake lines, 7mgte in progress...
2genfun is offline   Reply With Quote
Old 02-16-2012, 04:36 AM   #2
You upgraded the injectors or added 25% more fuel some other way I hope... Can't run more air until you've got more fuel or you're going to run lean and destroy stuff VERY quickly.
Old 02-16-2012, 12:37 PM   #3
are you talking housing or black box? if you replaced your stock metal honeycomb then yes, your going to ruin you engine unless you have a way of tuning. The black box used as a replacement for your kvafm (i.e my old one busted.) is acceptable and should not affect your daily driving. granted you wired it in correctly..
Old 02-16-2012, 03:03 PM   #4
pandrade
from what i have heard if you put the lexus afm you can also take its injectors which already flow 550cc which both will plug and play( i would get them flow tested first, dont want a bad injector)if you dont have the injectors you'll start damaging things really quick
Old 02-16-2012, 04:28 PM   #5
If the lex are low impedance. I don't think they are if I recall correctly
That's something I'd check into.
Old 02-16-2012, 07:49 PM   #6
The stock 1UZ injectors flow around 250cc/min.... NOWHERE near what even the 7M-GE's injectors flow. The 1UZ also uses high impedance/'saturated' injectors where the 7M-GTE uses low impedance/'peak and hold'. Actually, the 7M-GE's '89+ injectors are an upgrade for the 1UZ; '89+ GE injectors (with the green top) are high impedance.
The ELECTRONICS within the 7M-GTE and 1UZ-FE KVAFM are the SAME and may be interchanged.
The HOUSING of the two KVAFMs are different. The 1UZ's flows about 25% more unmetered air. As this air is unmetered and the ECU has no way of knowing that it needs to provide additional fuel to match the airflow.... Hence the REQUIREMENT for larger injectors; It's not an option.
Old 02-16-2012, 11:33 PM   #7
I thought they were high impedance. I was at work tho posting from my iphone.
can you make that a sticky please. or move to the faq.
Old 02-17-2012, 12:12 AM   #8
You thought correctly... they are. You can use high impedance injectors on an engine which came with low by removing the resistor pack but you cannot run high impedance injectors with an ECU that's built for low (at least not without a good amount of work... often including a different ECU ).
I'll move it to the FAQ for now. I may put together a more concise thread without all the additional chatter in its place later on. I didn't realize that this upgrade wasn't even covered in the FAQ.
Old 02-17-2012, 12:15 AM   #9
Ok. I've moved it to the FAQ. Everyone keep in mind that if you reply to this thread now it is moderated so your post won't show up until a staff member approves your post.
We haven't heard back from 2genfun.... Are we to assume he's busy swearing while pondering the easiest way to replace a piston with 'speed holes'?
Old 02-17-2012, 01:05 AM   #10
that explanation you gave, covered that question most thoroughly. It deserved a spot in the faq. Rather then repeatedly spouting it. Cheers!
HTML code is On
Lexus AFM Questions Chromemoly MKIII Supra 0 07-05-2009 02:55 AM
Lexus or Toyota AFM. What is the diference? azerty MKIII Supra 4 04-30-2008 01:08 PM
Diferences between Lexus and Toyota AFM azerty Non-Generation Specific Questions 1 04-29-2008 07:56 PM
Lexus AFM question? rnoswal MKIII Supra 13 04-20-2006 06:34 AM
