Old 07-14-2010, 01:00 PM   #1
mjg.. wered you get those stainless steel allen cap screws (6 X 1.5mm thread, 25mm long, 12 qty).
Old 07-14-2010, 08:41 PM   #2
907mge
907mge's Avatar
David @ twosrus has these if interested:
http://www.twosrus.com/catalog/produ...products_id=76
Or suprasport has these:
http://www.suprasport.com/Valve-Cove...Kit_p_295.html
Old 07-18-2010, 05:48 PM   #3
A fastener supply in just about any city should carry these bolts and grommets. The bolts are easier to work with but do not use them as an excuse to over tighten the covers. The spec is 22 INCH pounds for a reason.
I'm still waiting for someone to go with spring loaded fasteners with 2lbs springs.
Old 08-04-2010, 09:27 PM   #4
ok before I purchase
Metric socket head screws, Stainless A-2 (18-8), 6mm x 1.0 x 30mm Each
yea? no?
Old 08-05-2010, 01:15 AM   #5
I think I used 25mm; 30 should be just fine though.
Old 08-05-2010, 01:53 AM   #6
good, good
supra sport wanted 15 + 10 to shipp..
wanted 16+3 shipping
found something else online that was $3 for the screws and 10 for shipping. im looking tomorrow for something local. Ill just dig around till i find something I can pick up. so just as long as those specs work im in good shape.
thanks for the input
probably going to order these
http://www.boltdepot.com/metric-socket-products.aspx
so would you use the 25 or the 30? for length?
according to a sogi page they used the 30.
let me know Im gonna place the order tomorrow. if i cant find anything local.
also im no metallurgist. stainless steal? zing coated? the black finished ones? what will avoid corrosion and be a good strong bolt?
Old 08-05-2010, 02:33 AM   #7
25 or 30 is fine, grab whatever you find, I had originally used female hex bolts, but later replaced them with pan head conventional hex bolts... they're just regular bolts with a broad washer like surface to distribute pressure. Got them in stainless for around $5 at a local Ace hardware store.
Old 08-19-2010, 03:22 PM   #8
went to home depot and purchased zinc coated 6x30 socket cap bolts
7 dollars for 12.
HTML code is On
Valve cover vent hose Durandal MKIV Supra 3 07-14-2009 01:53 AM
Need a 14mm allen head bolt for valve cover trevor217 MKIII Supra 4 10-30-2008 02:50 PM
88 Turbo Leaking Valve Cover Gaskets Sheridan MKIII Supra 1 11-05-2007 01:03 AM
Valve cover gaskets vancouver874 Non-Generation Specific Questions 7 08-14-2006 07:28 PM
