Old 10-05-2007, 03:29 AM   #1
84cuddy
84cuddy is on a distinguished road
Default info on 1984 supra
I have'nt found much info for my 84 Supra.. Did they come with a turbo as an option? Any info would be helpful.....
84cuddy is offline   Reply With Quote
Old 11-22-2007, 11:00 AM   #2
'84SuperSupra
'84SuperSupra is on a distinguished road
Wikipedia FTW!!!
Originally Posted by Wiki
1984
In 1984, Toyota changed quite a bit on the Supra. Power output was increased on the 5-speed models with a bump up to 160 hp (119 kW) and 163 ft·lbf (221 N·m) of torque. The increase was achieved by a mixture of a redesigned intake manifold with "D"-shaped intake runners and an increase in compression ratio to: 9.2:1[3]. Another notable change in the 5-speeds was the switch to a 4.30:1 gear ratio in the rear differential. All automatic Supra's retained the previous years power numbers, but the rear gear ratio was changed to a 4.10:1.
The most notable exterior change was the switch to wraparound front turn signals. Also on the outside the tail-lights were redesigned and the hatch received a billboard "SUPRA" sticker instead of the smaller sticker, which was previously positioned on the right. The rear hatch and bumper was changed and received the same color as the rest of the car (instead of the black of previous years). The door handles were also switched around, opening by pulling up instead of sideways. This year Toyota also decided to offer two-tone paint schemes on both the P-Type and L-Type.
Some interior controls such as the steering wheel, cruise control, and door lock switch were redesigned. Toyota encompassed a 130 mph (210 km/h) speedometer instead of the traditional 85 mph (137 km/h) one and the automatic climate control display was also changed. The previous year's cassette/equalizer stereo option was now made a standard feature.
I'm considering buying one so I've been researching it a lot =D
http://en.wikipedia.org/wiki/Toyota_Supra
'84SuperSupra is offline   Reply With Quote
1984 Toyota Supra Repair Jake73 Non-Generation Specific Questions 0 12-09-2006 11:59 AM
