Old 06-23-2007, 02:31 AM   #1
bchap
bchap is on a distinguished road
Default supra rims on 240???
Do you know if rims off of a 1982 supra will fit a 1990 240sx?.... there both 4 bolt. Thanks
bchap is offline   Reply With Quote
Old 06-23-2007, 04:17 AM   #2
3RD STRIKE
3RD STRIKE's Avatar
3RD STRIKE is on a distinguished road
Default re , wheel swap
[QUOTE=bchap]Do you know if rims off of a 1982 supra will fit a 1990 240sx?.... I am not sure on that one. However i have done a datsun 280 zx to 84 supra swap. I know that u will have to change the lug nuts because the threads are different. Now i also know that i tried to put the supra wheels on the datsun -(which is a nissan in case you r not familuar with this car.)-and the rear wheels go on fine, but the front wheels will go on BUT..... the front studs on the datsun are too short for the supra wheels, so u have to use longer studs. I am going to the junk yard tomorrow. I will get some measurements for u to confirm tomorrow. I think it will work.
3RD STRIKE is offline   Reply With Quote
Old 06-29-2007, 06:45 PM   #3
kornkid
kornkid is on a distinguished road
We tried them on a datsun 200sx and the hub was too large. You will probably have the same problem on a 240 as the old 200's were similar to 240's.
82 Ptype (6mgte project)
kornkid is offline   Reply With Quote
Old 07-09-2007, 04:41 PM   #4
gpgtp_22
gpgtp_22 is on a distinguished road
I think they should fit because the bolt pattern is 4x114.3 and i believe that is the same as the 240. I've never tried it so i'm not positive but they should.
gpgtp_22 is offline   Reply With Quote
RIMS For My 1995 Supra markvenom MKIV Supra 3 10-30-2008 03:41 PM
Buying Rims For My Supra DarkRaiderz MKIII Supra 2 01-02-2006 11:18 PM
MKIV rims on an 86,5/87 supra???????!!!?!? RonPalm87 Non-Generation Specific Questions 2 10-05-2005 03:18 PM
rims for my mk2 supra Guest MKII Supra 1 06-01-2005 08:03 AM
