Old 10-21-2006, 01:44 PM   #11
supra1985turbo
supra1985turbo is on a distinguished road
just the seal can't be replaced? is the seal hard to get to?
No you have to replace the hole PS rack. on the MKII's
1985 celica supra upgrading to street/drag well mainly drag. Have complete HKS T4 turbo kit, electronics and all, Getting head port and polish with HKS 264 cams, and port and polished intake with 6 extra injector bungs. Eagle or crower rods? I just bought a 1990 MA70 n/a .
supra1985turbo is offline   Reply With Quote
Old 10-21-2006, 10:50 PM   #12
hangsupra
Originally Posted by supra1985turbo
Dose it smell like gas? If so you have a fuel leak in your engine compartment. It is not tipical to smell fumes in the car unless you have a leak. If it dose not smell like gas you might have an exhaust leak near the engine. What kind of fuel milage do you get? You could also have a leaking injector. Pull your oil dip stick and spell the oil on it. If it smells like gas than you have a leaking injector. If you do might as well replace all 6. You can usally find them on ebay for the 5MGE. If not look for the ones for the 7MGE or 7MGTE. they are higher cc's and will fit like the 5M's injectors!
i know that the 7mgte injector... will fit.... but what about the wired... does the stock wired harness snap on without cut n re-connect the wired....
Old 10-22-2006, 12:23 AM   #13
my 1984 celica-supra
my 1984 celica-supra is on a distinguished road
well I checked the oil and smelled no gas.the engine compartment does not smell like gas.I did find a bad gas cap replaced it and it still smells only when car is running.The gas mileage is probably around 23 mpg last i checked.It kinda smells like it is running way to rich.the car has 206,000 miles on it i guess i shouldn,t complain.I notice a little oil use when i start the car for the first time in the morning then clears up. I dont notice any smoke while driving though.it does not really smell like raw gas. I guess i will have to keep checking and maybe find something.
my 1984 celica-supra is offline   Reply With Quote
Old 10-24-2006, 12:35 AM   #14
hangsupra
so it smell's like gas or oil...
cause this might be the few things... that you might need to check...
1. check the O2 Sensor...
2. check all the exhaust gasket... might have a leak...
3. check the vaulve cell
4. double on your exhaust pipe from header to muffler... might have little tinny hoe on it.. that you might not see...
5. check afm... try to adjust to stock position... maybe you run too rich...
6. check your head see if it burn oil...
hope this might help you little bit...
correct me if i wrong to alright... people...
Old 10-24-2006, 01:51 AM   #15
ok thanks for all the help i will start checking all that.And take care of any problems.I will let you know how i make out.
Old 10-25-2006, 06:45 PM   #16
supra1985turbo
As far as I have been told by some friends that have 10 to 11 second supras that the 7m injectors will fit the 5m and the wireing
