Old 03-06-2006, 05:38 AM   #1
supramadness
supramadness is on a distinguished road
Question celica supra engin conversion
hey i drive an ra65 celica but my mate drives an celica/supra of the same eara and hes changing from a 5gme to a 5 lt chev engine (while getting haliquin pant by the way)now shold he just turbo his 5gme or go ahead with his conversion (altho i want him to cuzs hes gonna give me the 5mge for free to put in the celica hehehe and should i do my conversion from 22re to the 5mge if so what would be required and what sort of upgrages should i do to it first)but back to my mates car he aslo wants to know what kinda work would be required to get it in there
thanks heaps
dan (the supra lover)
p.s the celica was the closest i coulg get to a supra in my price range
hey i own a ra 65 celica its all i could aford (damm parents ) o well looks like i have to save for a mark 3
supramadness is offline   Reply With Quote
Old 03-09-2006, 04:49 PM   #2
Isphius
Isphius's Avatar
what celica do you have exactly? im not sure on their body codes. if its rwd, and the engine will fit physically (its not to long), it shouldnt be all that hard to convert. just have to make/get made custom engine mounts and maybe redo the trans cross member. and if the driveshaft should fit, but if it doesnt it doesnt cost a lot to get a new u joint put on it and have it shortened. any automotive machine shop should be able to do that. If its an automatic its easier, but if its a stick youll have to get the clutch master cylinder or linkage and pedal from the 5m car. also the speedometer might not work with a new transmission, so you may have to find one of those, and the shifter might come out in the wrong place so itll feel weird and u may haev to modify the interior.
Old 04-08-2006, 06:30 PM   #3
hangsupra
well... first what year is the celica. is it the celica gt n back wheel drive or is it the front wheel drive celica. especially what year is the celica. cause i got a '76 celica gt with the 7mgte motor on it. and it fit perfectly.... so if you can get the celica around that year sure fit the 5,6,7m on it. it sure fit perfectly no proble. but need to work on the drive train little bit.
Old 04-10-2006, 12:00 AM   #4
midwestmk2
midwestmk2's Avatar
You will have to relocate the radiator to the front of the support for it to fit..The RA65 uses the same suspension,tranny,etc..Except that it has a shorter wheelbase and some came with solid rear end not the IRS..So the 5MGE will fit just little mods like the radiator,motormounts from a supra,ECU,all sensors and the MAF plus the harness..So if your friend goes through with it just get the engine,tranny,driveshaft and everything else and your in buisness..If you have a solid rear axle you wont be able to use the driveshaft..On your friend he will have to do alot..Fab custom motor mounts,custom exhaust,custom tranny crossmember,custom driveshaft,etc,etc,etc....Wow the work...
P.S. dont save for a MKIII they are PIGS...
JDM Supra conversion to USDM Supra Feel-IX MKIV Supra 3 05-31-2007 06:05 PM
