Old 04-30-2013, 11:53 PM   #1
86supra
86supra is on a distinguished road
Default wont start need help
no spark drove it to wont ran fine left work nothing went and got a new coil for it fired up little hisitent but fired run for about 10 mins fine truned it off went to start it up bout 8 hr later nothing no spark just like before need some help plz and thank u
86supra is offline   Reply With Quote
Old 05-01-2013, 02:57 AM   #2
If legible will try to help cannot understand a thing youre saying sorry please try again because i hate to think of broken down supras rusting in junk yards
Old 05-02-2013, 02:02 AM   #3
http://www.toyota-supra.info/forums/...need-help.html
once again check for your damned codes.
report back with a legible response in THIS thread. creating a new thread for problems you have been having for months is not going to help.
would love to help but we need more.
Old 05-02-2013, 11:20 PM   #4
86supra
My bad sorry. is a new prob tho. last one ended up beine a brokin starter wire. started and ran good for a cuple week. then drove it to work ran fine. went to leave work woulnd start. starter cranks fine. can smell gas so checked for spark had none form the coil so i got a new one put it on that moring start fine. went to start it about 8 hr later no start again seems to only start in the am . neg battary wire gets a little hot while tryin to start it maybe a loose ground idk
Old 05-03-2013, 12:04 AM   #5
86supra
My bad sorry. is a new prb tho last one ended up being a bad starter wire . it ran fine for a bit now wont start. starter cranks and can smell gas but no spark check it no spark comein form the coil so got a new one put it on started fine .shut it off went to work bount 8 hr later tried to start it no spark again same thing the next day likes to start in the am idk
Old 05-03-2013, 12:09 AM   #6
first words used in your previous thread:
just starte dactin up in the last week sometime it will start and run fine but more and more it just wont start
test your coil :
http://www.cygnusx1.net/Supra/Librar....aspx?S=IG&P=7
and for the third time check for codes....
Old 05-03-2013, 12:22 AM   #7
86supra
its a band new coil just got it 2 days a go form slow motion motorsports i cant figue out how to check the codes cant find that check connecter it talks about
Old 05-03-2013, 12:34 AM   #8
http://www.cygnusx1.net/Supra/Librar...ection=FI&P=22
its time to read. and look at the picture where it shows the connector.
using a test light. test for power going to your coil, and ensure all your grounds inside the engine bay are secure and not corroded, just because you wiped the grease off the top of the grounds does not mean it has good contact.
Old 05-05-2013, 03:16 AM   #9
86supra
alright i got codes 11 14 and 52 so iam trying to find the relay and check that but it starts in the moring fine but in the afternoon it wont start at all no spark i dont get
Old 05-05-2013, 03:25 AM   #10
Those are all very significant codes and need to be addressed. http://www.toyota-supra.info/forums/100107-post41.html
I'd start with disconnecting and thoroughly scrubbing all of the primary grounds and the positive wiring (especially in the engine bay). EDIT: The code 11 and 14 may be explained by power problems, but the code 52 is something else. Usually the knock sensor is bad or the wiring.
car suddenly wont start - never ran great anyway, esp. cold, now cranks, but won't st rjSupra MKIII Supra 41 03-21-2014 05:27 PM
Roll start but no key start. Need help Mrow MKIV Supra 1 09-11-2011 06:11 PM
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
87 non turbo wont start, need some advice...please. HotRodV6 MKIII Supra 3 09-02-2010 07:29 AM
Stalling at start up Green7mgte MKIII Supra 4 12-15-2009 06:31 PM
