Old 01-18-2011, 06:08 AM   #1
GLENN
GLENN is on a distinguished road
Default 85 Supra intermitent loss of power while driving
This started happening for 2 seconds at a time and now I loose power completly but engine is still running. When I try to accelerate it dies. If I put in neutral it revs a bit rough but does not go off.
If I let it sit for about 3 hours I can start it with no problems at all. So it is random.
Can anyone help with suggestions?
Thanks
GLENN is offline   Reply With Quote
Old 01-18-2011, 07:48 PM   #2
Sonyps307
Did you pull for codes yet
Old 01-19-2011, 12:24 AM   #3
GLENN
Default No engine light comes on - Did not pull codes
I did not try to get codes as there was no engine light on the dash when it happens.
I am going to try and put a new fuel filter as it's been a couple of years.
Do you think it can be the ECU as it is random?
Thanks for the advice
Old 01-19-2011, 01:04 AM   #4
Sonyps307
Also might be a stopped up cat if U change the fual filter u should pop off the cat and look in it I heard of the metal in side falling apart and turns in to a ball and will get stuck in the pipe then when it cools down it falls out the pipe and back in the cat
Old 01-19-2011, 02:27 AM   #5
ill put my vote on fuel filter.
but like sony said check for codes
Old 01-26-2011, 04:09 AM   #6
supkar
supkar is on a distinguished road
Agreed---fuel filter. Still runs but no power. Barely getting enough gas. Happens after you drive it a bit and gets worse over time. Not fun to change.
supkar is offline   Reply With Quote
Old 02-07-2011, 01:46 PM   #7
GLENN
Default Where is the Data Link Connector for 85 Supra
I have taken my Supra from Canada to Australia and had to convert
from left to RIGHT Hand drive. The wiring and firewall had to be reversed.
So it is not original and I cannot locate where to plug in the code reader.
Also I have an OBD2 Reader will this be compatible?
How many pins should the connection have (male or female)?
Can anyone tell me where it is located on the original Canadian model?
Is it a fixed connection on a bracket or a loose cable?
Thanks guys
Old 02-07-2011, 03:58 PM   #8
Sonyps307
A 85 supra will not have obd2 it didnt come out intill like 95-96. U will have obd1 and it's out in the engine bay
Old 02-08-2011, 02:09 AM   #9
i think its ei and tei that needs connecting.
normally found by the ignition coil and battery.
i will take a picture of the plug tomarow
Old 06-22-2011, 09:52 PM   #10
DaddyOH!
DaddyOH! is on a distinguished road
Default Check fuel pump flow rate
Had the same problem. Got the fuel filter off and decided to test flow BEFORE the filter. With the fuel test lead jumped and the key on the pump should be able to produce just under a gallon of fuel in one minute. Mine was doing less than a half gallon. Found my pump screen in the tank to be clogged. Cleaned scale from tank and replaced screen and happy days are back!
DaddyOH! is offline   Reply With Quote
power windows on mk3 supra (89) aaronced MKIII Supra 3 11-25-2009 10:41 PM
Loss of power and electrical fire mister MKIII Supra 0 12-16-2008 10:17 PM
supra horse power Jeriko Suratos Non-Generation Specific Questions 5 06-24-2005 04:00 AM
