Old 03-24-2008, 09:51 PM   #11
bleSId
bleSId is on a distinguished road
Originally Posted by Supra Goddess View Post
freightliner truck? what does that mean? very high psi or very low?
the other numbers seem good, fairly consistant.
the oil between the cam towers is either the valve covers or cam tower gaskets leaking, a pretty common issiue with these engines after so many years/miles.
the numbers are extremely high i the highest reading we got was a little over 210psi
bleSId is offline   Reply With Quote
Old 03-24-2008, 10:06 PM   #12
Supra Goddess
Supra Goddess's Avatar
Supra Goddess is on a distinguished road
210 isn't outrageous, but it is a little suspicious. more than likely there is oil sitting utop the cylinder, either caused by bad rings on that piston, leaky valve stem seals or worn valve guides.
was the spark plug in that cylinder kind of oily?
Supra Goddess is offline   Reply With Quote
Old 03-24-2008, 10:13 PM   #13
bleSId
ther was no spark plug in the number 3 cylinder
Old 03-25-2008, 03:06 PM   #14
Supra Goddess
OY...
this whole situation is a big headache for me just trying to understand wtf is going on here.
so no spark plug, doesn't mean it exploded, just means that someone is an assclown, removed it and didn't put it back... OR... didn't tighten it and the compression blew it out of the cylinder when someone tried to start the engine.
Old 03-25-2008, 10:01 PM   #15
bleSId
a head ache for you? you dont even own the damn thing!! imagine how I feel!
anyway, the compression didnt blow it out there is no scaring at all to threading, so far everybody is telling me that the sparkplug detonated when the timing belt blew, but those two things arent neccesarily connected to eachother, i think it was just bad timing*no pun intended*
Old 03-26-2008, 01:29 AM   #16
Supra Goddess
I mean it's a headache just trying to figure it out through typed words on the internet, it's hard to grasp what is going on here.
As far as the spark plug goes, I highly doubt that it detonated to the point it just 'disappeared'. There's no sign of the spark plug right? I find that very improbable. Shine a flashlight into the spark plug hole and see if you can see anything that doesn't look right, like metal chunks. The top of the piston should look black from carbon, which is normal.
Old 03-29-2008, 10:58 PM   #17
bleSId
all six cylinders are black.
nad
Old 03-29-2008, 11:00 PM   #18
bleSId
and yes there is no sign of the spark plug, but as you said before, that is probably the result of the mechanics not knowing what they're doing
Old 04-02-2008, 06:36 AM   #19
stormrally
stormrally is on a distinguished road
possible reason for high comp in 3 is high carbon build up. I read about a civic that had a static compression of 13:1 (from normal 9.5:1ish) just from carbon build up and ran race fuel until he rebuilt the engine. Speaking of, if you've rebuilt 2 engines already you should have a strong grasp on whats going on because really...an engine is an engine...unless it's a wankel. Ask the car these questions 1) are you getting air 2) are you getting fuel (how long was it sitting aka bad gas) 3) are you getting spark. of course if cam or spark timing are off it may not run as stated previously. check all that and if it still doesn't run suck it up and pull the head.
stormrally is offline   Reply With Quote
Super Monitor IHateHacks MKIII Supra 19 12-15-2013 10:59 PM
Hks super afr dieseltech24179 MKIII Supra 0 12-24-2008 05:56 PM
just bought a 1993 mkiv twin turbo, need help 1993suprawr MKIV Supra 66 10-10-2008 11:16 PM
just bought supra black_knock313 MKIII Supra 2 06-29-2006 07:33 AM
