Old 03-16-2008, 06:47 PM   #1
chrism8799
chrism8799 is on a distinguished road
Default please help
please help me i cant figure out why this 1983 supra wont start i am getting no spark i have a replacement coil and igniter on it and still nothing any help would be great please
chrism8799 is offline   Reply With Quote
Old 03-17-2008, 02:00 AM   #2
Supra Goddess
Supra Goddess's Avatar
Supra Goddess is on a distinguished road
Check your fuses. The ones in the fuse box near the battery AND the fuses in the drivers side kick panel. There's an ignition fuse in the kick panel that will make it not start. Also, make sure the ignitor is grounded properly and the other grounds are good too (ground from engine block to battery, ground from transmission to chassis, ground from back of head to chassis, ground from the wiring harness to a bolt on the intake manifold...it's on the underside of the manifold)
Supra Goddess is offline   Reply With Quote
Old 05-19-2008, 05:57 AM   #3
supramacist
supramacist's Avatar
Did you have to build your wires? If so did you do it correctly?
Are they still fastened?
What plugs and wires are you running?
Have you looked at the dizzy and the rotor and all of that?
