Old 03-20-2008, 02:12 AM   #1
fexterz11
fexterz11 is on a distinguished road
Exclamation ct26 upgraded to 60 trim.. Good or bad?
Hi guys, there is a guy selling a ct26 upgraded to a 60-1.. are the intake and exhaust housing of the ct26 capable to hold this good? do you think is worth buying it??
fexterz11 is offline   Reply With Quote
Old 03-20-2008, 03:14 AM   #2
mkiiisupra
Most people agree that the turbo has a short life span, that its just pushing the housing too far...
There are actually a few turbo rebuild shops that will not put at 60 trim into the ct26 becuase they do not recommend it
1990 Toyota Supra Turbo A/T
Old 03-20-2008, 03:55 AM   #3
fexterz11
yeah that was my concern.. 60 is pretty big for that turbo.. i see you have a 57 trim upgrade.. is that in a ct26?? how is it working for you?
Old 03-20-2008, 04:00 AM   #4
mkiiisupra
yeah its in the ct26, works well have not put even 5000 miles on it yet tho
Old 03-20-2008, 04:10 AM   #5
fexterz11
so if i get another ct26 and upgrade to a 57 trim it would be just about right?? did you notice any power gains? oh! and by the way this is going in an MR2...
Old 03-20-2008, 04:26 AM   #6
mkiiisupra
power gains? This was pulled from Doward over at SupraMania - Powered by vBulletin
CT26 (stock):
Compressor Inducer: 1.75"
Compressor Exducer: 2.559"
Turbine Minor: 1.97"
Turbine Major: 2.36"
Good for approx ~31lb/min (about 450cfm) of airflow, around 13.5psi. I would not exceed 13.5psi, though you will hear of people pushing 20psi. If you want the turbo to last, do not exceed 13.5psi.
CT26 Upgraded:
The CT26 upgrade is great for those on a budget, or if you want a super-fast spool. The upgrade consists of sending your stock turbo off to a turbocharger shop, and having them bore out the compressor inlet to fit a larger compressor wheel into the CT26. Generally, T04e wheels are used, though I have heard of T04b wheels being used. Bang for the buck, it is hard to beat the upgraded CT26.
The downside to that great spool, is you still have the restrictive exhaust.
Upgrade levels one may choose from:
50 trim - Considered the most reliable upgrade.
Compressor Inducer: 2.12"
Compressor Exducer: 3.00"
The T04e 50 trim wheel is rated @ 44lbs/min @ 2.0PR, and 65% efficiency at that point.
57 trim - The most popular upgrade, while still being very reliable.
Compressor Inducer: 2.23"
Compressor Exducer: 2.95"
The T04e 57 trim wheel is rated @ ~40lbs/min @ 2.0PR, and 60% efficiency at that point. Raymond Khublal in Orlando, FL has laid down 422.1 rwhp/460.2 rwtq as shown on 7Mpower.com with this turbo.
60 trim - Not to be confused with the 60-1 upgrade, this is a less reliable variation of the 57 trim. More power is to be expected from the 60trim vs the 57trim.
Compressor Inducer: 2.29"
The T04e 60 trim wheel is rated @ ~46/min @ 2.0PR, and 65% efficiency at that point.
60-1 (T04b) The 60-1 is a T04b wheel, and the biggest I have personally seen on a CT26. The least reliable upgrade, but has made the most known power.
Compressor Inducer: 2.324"
The T04b 60-1 wheel is rated @ 56lbs/min @ 2.0PR, and 65% efficiency at that point.
Something to keep in mind - these wheels are rated at a specific flow WITHIN their own respective compressor covers. The CT26 cover is small, so you will not get the 56lbs/min you want with the 60-1. This also holds true with the T04e 50 trim - it seems the best on paper, but I have yet to see one crack 350hp. I would love to see a 20psi run on a tuned 50 trim, to find out if that larger exducer is holding it back or not.
I will add the JT, SP, and BOSS series turbos later.
Window trim question Isphius MKIII Supra 11 09-28-2021 05:52 PM
Rear Right Trim D_Train MKIII Supra 3 07-14-2007 10:01 PM
ct26 57 trim whitemk3 MKIII Supra 6 12-03-2005 03:49 AM
rebuilt and upgraged 50 trim.. joel w MKIII Supra 0 10-23-2005 05:52 AM
