Old 09-09-2007, 03:29 AM   #1
Toyotafanatic
Toyotafanatic's Avatar
Toyotafanatic is on a distinguished road
Default Painting my car myself, can it be done?
Ok, so Im thinking about getting this built MkIII but its the color I really cant stand, burgandy, would it be realistic since I have a compressor, to go buy some spary guns for the compressor and some paint for the car and paint it myself, Im pretty experinced in painting but have never taken it to this extreme, what I want to know also is how good will it look, and what kind of paint I need, base coat, gloss etc, and the type of paint I should use, and how much does this paint run for, oh if youre curious and what color the car is going to be, Im just going to go with a simple black. If you could guide me in the right direction that be great cause I dont want to go blow a ton of money on a pro paint job.
BOOST IT!
Toyotafanatic is offline   Reply With Quote
Old 09-09-2007, 09:13 PM   #2
Toyotafanatic
anyone? pics of people doing it them self would be cool too
BOOST IT!
Old 09-22-2007, 05:36 AM   #3
4ageBT
4ageBT's Avatar
4ageBT is on a distinguished road
youl'l be needing tons of hardwork and patience in preping up the car for painting. the secret of a good paint job is on the preparation of the body.
Autoparwarehouse blog..
4ageBT is offline   Reply With Quote
Old 09-25-2007, 01:58 PM   #4
SCRAMJET
SCRAMJET's Avatar
here is a few pics of my effort before and after. Mine took 150 hours and as you can see the body and paint were very good before i started. I did mine in Artic pearl white, a zerallic pearl used on 2003-2006 subaru imprezas and wrx's. It's a massive job if you want to do it propperly. I did all the prep work at a mates panel shop but i left the painting to the proffesionals. You gotta know what your doing before you try the job on your own. I dont think just owning a compressor is enough
ID:	1077   Click image for larger version
ID:	1078   Click image for larger version
ID:	1079   Click image for larger version
ID:	1080   Click image for larger version
1jz scramjet mkiii
Old 09-25-2007, 06:11 PM   #5
supra_91
supra_91's Avatar
when your painting im pretty sure you have to be in a dust free environment with proper air circulation. i think it also matters how much pressure you put through the gun
Old 10-16-2007, 02:01 AM   #6
supradrift
supradrift is on a distinguished road
when you are painting you have to be in a climate controlled room with little humidity. you need to buy paint the right hardner for the kind of paint and the right thinner. everything needs to be mixed right with the right air pressure and the right motions to paint. if you mix it wrong you will have orange peel and wont look good.you have to spray evenly or youll have runs. if you do enough layers it doesnt matter how good you paint it if you have enough patience to wetsand it which is a pain in the ass then buff it
supradrift is offline   Reply With Quote
Old 12-24-2007, 02:45 AM   #7
Pretaco
Pretaco is on a distinguished road
Default Paint
Haven't tried this yet but interesting:
moparts: paint job on a budget!?
another thread about it:
Sweet $50 paint job - Pirate4x4.Com Bulletin Board
I want to try it one day on my beater truck.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
Pretaco is offline   Reply With Quote
Old 03-12-2008, 07:05 PM   #8
twerb089
twerb089's Avatar
twerb089 is on a distinguished road
yea, i used behr house paint and rolled it on... i did that like 8 months ago and im still not done sanding, although im procrastinating most of it.. but it got the job done and it was only like 50 bucks
1989 supra turbo automatic soon to become a manual
K&N, megan dp, gutted cat, 2 1/2" magnaflow cat back
NA intake cam, shimmed actuator
no A/C or P/S, therefore no ac condensor, compressor and no ps pump or resivior.
gutted interior, 4 tweeters, 2 kicker 12"s powered by an MTX 400W 350rms and an audiobahn 400W 300rms
twerb089 is offline   Reply With Quote
Old 04-05-2008, 03:45 AM   #9
chucks
chucks is on a distinguished road
The DIY Paint job > they have a nice layout of how to do it.
Autopartswarehouse rules coz Autopartswarehouse rocks!
chucks is offline   Reply With Quote
Old 09-10-2008, 11:22 AM   #10
shiftysupra
shiftysupra's Avatar
shiftysupra is on a distinguished road
Red face
If your experienced in painting and prepping should come out pretty well. My dad and I used to paint many cars as he was a body man at Thoroughbred Nissan here in Tucson. Prepping is honestly about 90% of the work.
shiftysupra is offline   Reply With Quote
painting my grill? newbsupra MKIII Supra 18 09-03-2006 12:55 AM
Painting my rims? OmeGa MKIII Supra 2 07-26-2006 02:39 PM
Painting My Mouldings.. newbsupra MKIII Supra 2 07-13-2006 07:44 AM
Painting my 87' Supra Poptart Non-Generation Specific Questions 1 06-26-2006 09:45 PM
Painting Interior Johnny boy 82 MKIII Supra 2 06-09-2006 03:09 AM
