Closed Thread
Old 02-11-2010, 01:45 PM   #1
jgheels2003
jgheels2003 is on a distinguished road
Default FS:NC: 1997 Deep Jewel Green MK4 6sp,single turbo
Deep Jewel Green, targo top 1997 six speed Supra
-Lien holder is USAA, VIN# JT2DE82A5V0037200 Clean Carfax
-Non-smoker 112,500 on chassis, ~4000 miles on current oem block.
-T-70 turbo
-Fuelinjectorclinic.com fuel system with 1000cc injectors & dual OEM denso pumps
-RPS stage 3 six puck clutch,RPS Synergy lightweight flywheel (will chatter at idle when not engaged=normal),
-HKS 264 cams ,HKS SSBOV,Innovative Wideband, AEM EMS , HKS DLI, HKS FMIC
-Greddy PE catback (NO DRONE)
-boost controller
-boost gauge
-stock wheels , rears widend to 12'' with custom gunmetal paint job,
TRD front strut tower brace
-6spd swap with auto rear and TRD differential.
The previous owner had the valves cleaned and head polished and a new oem shortblock with ~2000 miles installed before I purchased it. Since purchase I have had tuning done by Doug Wilks from Topspeedsales in Ga. 18 psi ~ 540 whp on 93 octane. New Map sensor, rear located battery upgraded with all Stinger cables, 0 Guage/4 gauge, Stinger fused distribution blocks with volt reader up front, Stinger terminals (+ end volt reader) and Stinger kill switch. All are running high amp fuses. New starter contacts intstalled. A brand new Optima red top with case, new pump relays and grounds installed. As of 1/21/10 compression testing done at First Quality Auto in Greensboro using closed throttle and running cold show all cylinders 9.4- 9.7 bar less that 3% variance (open throttle should raise ALL numbers, especially when warmed up). Ext. with minor dings and scratches, approx. quarter sized ding on driver side rear quarter. Interior is in good shape front seats showing a little wear, same for front oem mats. Would recommend replacing power wire that plugs to CD player harness. Does not have rear hatch carpet support. Front and rear tire ~80+ tread, would recommend drag radials for Spring/Summer
$25,250 OBO I'll try and answer any questions, email at jgheels2003@yahoo.com. Thanks!
jgheels2003 is offline
Old 02-11-2010, 05:22 PM   #2
kamikazemkiii
kamikazemkiii is on a distinguished road
WOW, if i had the money that would be mine!
Good luck with sale!
kamikazemkiii is offline
Old 03-16-2010, 12:12 PM   #3
kyle2614
kyle2614 is on a distinguished road
would you consider trading for an '07 wrx sti?
kyle2614 is offline
Closed Thread
