Old 12-17-2011, 10:45 AM   #17
Bill UK
AEM EMS
Bill UK's Avatar
Sounds like the gear has been installed 180 degrees out of position on the shaft; the only drawback is when you install the CPS (as you said) you need to turn the gear 180 degrees to compensate. Found this photo below of a CPS when the notches are line-up. Personally I would leave it as it is; it’s only the grove/hole on the gear/shaft that would be wrong for installation.
