Old 12-15-2011, 06:01 AM   #1
87hilux7mge
87hilux7mge's Avatar
just be careful, if the hose is slightly smaller, you can cut the hose while putting it on which will compromise its integrity. also, after heat cycling, if the hose is too small for the neck, it will crack easily and could lead to a premature failure.
neway, just be careful. good luck with it.
