Old 12-10-2011, 10:54 PM   #1
If it's not turning over at all, start with pulling the EFI fuse and verify that you can rotate the crank (to make sure something in the powertrain isn't locked up.
Then check the primary ground from the engine to the battery and the power line from the battery to the starter (there are two wires which run to it: primary and solenoid, the solenoid obviously has power).
