Old 12-06-2011, 10:52 AM   #3
dlfred
dlfred is on a distinguished road
That was it. I found a good bit of coolant in around 2 or 3 plugs. Did as you said and it runs like it did before I dumped coolant all over the top of the motor. Thank you.
My car still runs at 1200 rpm and has always had a high idle since I purchased it. The throttle stop screws are backed off and not doing anything idle related.
Is there a dash pot setting in the shop manual?
Has anyone had a problem with the water being pushed into the coolant overflow tank? This was happening before the HG repair and is still a problem.
Will a high idle do this?
No smoke from exhaust. No water in oil. No fluid on the ground.
Thanks again for the input on the poor running condition.
1986 Supra 3.0 NA Stock
5 Spd. Lexus rims 16 x 7
dlfred is offline   Reply With Quote
