Thread: Hello
Old 12-06-2011, 02:04 AM   #2
Originally Posted by Turboron_99 View Post
So i would need a 60.1mm inside to 83.82mm outside diameter Hub Centric ring?
Yes, something around there. A local tireshop should be able to hook you up with some plastic ones for just a couple dollars.
Originally Posted by trd_brad View Post
i have 255 on 17s 10 wide fit no problem im sure 16x8 or 16x7 will fit no probs
But at what offset? If they're 35 or 40 it'd be just about perfect... but an offset of 0 and you're going to have 2" of rubber sticking out past the fender.
