Old 12-05-2011, 12:09 PM   #30
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by [SupraLEGEND] View Post
...judging by the conversations I have with the dealer, their urgent responses and willingness to answer all my questions about the cars,...they have sent me numerous pictures of each car allowing me to see it's condition for myself and that it has A, B, C upgrades installed...
Then ask for a picture of this so-called "racing clutch". They'll have to put it up on a lift (or jackstands), and remove the dust covers in the bellhousing to do so.
...more importantly than that, a clear picture of the '93 RZ's odometer was taken showing me the exact mileage of the engine....
Disagree. The engine could have been swapped, as the odo panel also could have been.
...Depending on the previous owner's driving skill, do you realise that the OEM clutch or "racing" one will feel quite good (new) since it's very low mileage?...
I bought my Mkiv Supra Turbo brand-new from Toyota. Do you really need to ask that question? What I'm saying is the seller should call it a "racing clutch" if in fact it is a non-upgraded oem clutch. If the seller does that, to me it falls under the crime of false advertising.
...Can you agree that the engine it has is from an RZ/S Twin Turbo Supra - 2JZ-GTE and the engine type is the main thing when discussing N/A or Turbo?...
Yes to your first question (it has a 2JZ-GTE), and NO to your second one. The main thing when discussing NA or Turbo is the whole package. An n/a with a 2jz-gte does NOT perform OR have the upgrade potential of the TT. Period. The thing that makes the Mkiv Supra Turbo so special - the one thing that truly distinguishes it from all other GT sportscars of the '90s - is how insanely overbuilt it is. It's almost unbelievable that Toyota would have shipped a car (the Toyota Supra Turbo) advertised at 320hp with the following characteristics, but they did(!):
- 6spd transmission and differential capable of well beyond 1500rwhp
- Differential capable of well beyond 1500hp
- Shortblock capable of 1000hp.
- Entire Mkiv Supra Turbo is capable of a rock-solid reliable 450rwhp with just a few simple modifications
- Entire Mkiv Supra Turbo is capable of a rock-solid 750rwhp with a turbo+fuel swap and a simple 'piggyback' fuel controller
- etc.
All of these characteristics are in the Mkiv Supra Turbo, and not in the Mkiv Supra N/A. So honestly, the "main thing" when discussing Turbo vs. NA is the whole package, and not just the engine.
...You also know that it has very high level aftermarket suspension, fuel pump, upgraded pads, TCS installed and 1.5 way LSD - all of which make up for the N/A's shortcomings or at least make up for them to some degree?...
No. First of all, these "upgraded pads" are just heresay - to me, the braking system has not been upgraded at all. Secondly, most people consider the transmission and differential to be pretty important parts of any vehicle...both of which are MUCH less capable in the n/a version.
...The previous owner clearly wanted to transform his SZ into an RZ and aimed his choice of upgrades at the OEM's level or a level above in some cases (he just left out the tranny why)...
Disagree. To me, the previous owner clearly realized he had made a mistake by buying an n/a and took a few steps to attempt to rectify that mistake by upgrading the engine and the suspension. He probably then realized how much more it would cost to bring the rest of that n/a Mkiv up to full TT specs, so he decided to abandon the project. In hindsight, the right thing for him to do would have been to sell the n/a and buy a TT instead...and then put the upgraded suspension on that much more capable base platform.
...In other words, do you agree that, a 2JZ-GTE wasn't just dropped into an SZ and left as is?...
As you agreed above, this was a project abandoned part-way through.
...Which is more affordable from the 3 braking brands you listed?
None of them are really that affordable, honestly. We're talking thousands of $US to do the upgrade. Unless you're roadracing beyond the capabilities of the Mkiv Supra TT US-spec calipers, and you've already installed true "racing pads" (eg. Carbotech™ XP8™) and brake ducts, the cost would not be justified.
Again, we must agree to disagree on the topic of whether or not one should consider that particular n/a-T that is for sale a "full RZ/TT". It's wasting bandwidth in this forum, so please don't post on this one point anymore okay?
If you'd like, we can continue this debate privately.
Life begins at 30psi.
