Old 12-05-2011, 02:46 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by MarkN10 View Post
Cool man, what about converting non turbo to turbo?
For the Mkiv, the primary factor you have to keep in mind is that the car is more than just an engine. The Mkiv's braking system (calipers, abs), suspension, ignition, transmission, differential, etc., etc., etc. are all much more capable in the TT version than the n/a. Sure, you can slap a turbo on an n/a and make a few more ponies, but you will not end up with a TT. If you want a TT, wait, save up some more $, and get it. It'll be significantly cheaper in the long run to do this than trying to turn an n/a into a full TT.
Life begins at 30psi.
