Old 11-27-2011, 05:31 PM   #33
warmkop
Moderator
warmkop's Avatar
warmkop is on a distinguished road
Default Need help making power 94 TT
TSI modification#1
That neo do you wire it in or is it plug in.Just asking wat is the reason for not using the gotech or is the oem ecu that good. what about al the old sensors wont it make problems on the ecu if its disconnected. Just have a look at this chip.
http://www.dastekpower.com/home.htm
TSI Modification#2 Forgot i do have a wastegate will sent pics
TSI Modification#3: Do i need to upgrade the oem fuel pump or is it okay
TSI Modification#4: The clutch was on its wear limit.Took the clutch in and made it 5 puck button.The pressure plate is also made stronger
The old oem flywheel is very loose can turn it 45 degrees still need a flywheel.
My readings last time was 155 but our atmospheric pressure is 85kpa can be the reason its lower.
warmkop is offline   Reply With Quote
