Swap in Bilstien dampers and adjust the spring perch as you see fit. If you don't like how they sit you've got three placements to choose from, I think.... Or you could save up and get coilovers (the only way to go if you want control over height AND ride quality). There are a lot of reasons NOT to cut springs... the fact that Eibach Pro Kit are progressive and not linear is in the top three.
