Old 11-22-2011, 01:14 PM   #1
yoshi123
yoshi123 is on a distinguished road
Thanks, I'll try to check all the grounds. My mechanic says harnesses and such like just don't fail in Toyotas though. I have to work through
- coil packs test
- spark plugs
- ignitor test
As the car warmed up, then failed. Cooled down for 1h20mins then ran. I am considering something is getting hot and failing e.g.ignitor.
The TOMS ecu does a few things, delimits boost, delimits speed. Ignition timing advance (more responsive lower rpms). Boost seems to be set to 1.6bar on this one if you let it control the solenoid - my solenoid is controlled by Blitz boost.
If you run it, you'll need 99RON at worst, 100RON ideally.
No links but you could check the TOMS website.
yoshi123 is offline   Reply With Quote
