Old 11-22-2011, 05:07 AM   #2
The fluid level may also appear fine if you check it while the master cylinder is still pressed in. Prop the clutch pedal up and then check the fluid level. While you're on the floor check if the floor or the firewall (coming down from the cylinder) feel wet or oily.
