Old 11-21-2011, 10:23 PM   #1
Busted Knuckles
Busted Knuckles's Avatar
Jay, the clutch pedal will sit on the floor anytime it gets no pressure build-up. I've noticed this in many makes and models. You'll need to reach down and pull it back up.
If the system is sound, and it was just expelling an air bubble, the pedal should now be firm.
If there is still no pressure, try bleeding the clutch system. If that doesn't work, you probably have a bad master cylinder that cannot transfer pressure to the slave cylinder. This is based on your mention of plenty of fluid and no obvious leaks.
