Old 11-19-2011, 07:34 AM   #34
warmkop
Moderator
warmkop's Avatar
warmkop is on a distinguished road
Default need help making power94tt
Was just asking about the 2fuel lines you never now maybe you guys do things different becuase your 1/4 mile times is much faster then our times in SA.
What i did with the clutch kit is use the old clutch centre piece and made it a 5 puck button and the pressure plate i took in and made the pressure more on it when it brakes i would like to go to multiple disk.On the flywheel im using the same design as the stock flywheel to get more weigth out of the aluminium flywheel,and wil be able to modify the flywheel later for the multiple clutch kit if it doesn't work i wil just buy a clutch kit with flywheel.Wil sent you pics as soon as its finish.
The reason why i want to use the fuel cell is it can take 2 big external pumps with out any hassle with a new feed and return lines, i can also use the stock fuel tank with pump to supply a surge tank and use 2 pumps from the surge to supply.
I like trying to build things my self if it doesnt work i wil safe up and buy a brand name would like it if my supra can do 10s but it wil take time.
warmkop is offline   Reply With Quote
