Old 11-17-2011, 07:34 AM   #1
turbonicsperformance
turbonicsperformance is on a distinguished road
I wasn't blowing off any suggestions just answering them. when asked if the crank was straight Yes it was checked and yes it was straight. Same with the block etc. Im not sure what CV means but i'm guessing its when I explained my instructors credentials?? If thats what it was i was explaining why I trust what i was taught. I mentioned being an engine builder to cut out unnecessary explanations or having obvious questions asked not to show off. Its kool though I didn't take it too personally just gets under my skin when people assume crap over the internet. If i wanted to just blow off all the suggestions I wouldn't have asked in the first place...
just fyi after typing out that i may have check one rod twice I realized I still have the rods from the engine that I didnt use. I looked at them closely and realized one of the caps had a G on it...... I put that on the rods i wanted to use and only wrote it on 6 rods -__- so I installed a known bad rod........ explains alot but all the other crap didnt help either I'm hating myself quite a bit right now. I guess I shouldve paid better attention and slowed down. oh well though you win some and you lose some looks like i lost this time. sending everything out to be machined monday. then onto making some cash for a new cooler setup and oilpump. looks like the moped will be getting alot of use for the next few weeks /:
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
turbonicsperformance is offline   Reply With Quote
