Old 11-16-2011, 03:43 PM   #1
turbonicsperformance
turbonicsperformance is on a distinguished road
the block is perfectly straight i checked it before it went together and just today when the crank was removed . it was rod #2 again im pretty sure that rod was out of round or something. its gonna run me 185 to have the crank and rods all redone. the block is gonna be flushed using brake clean at 120psi if theres anything in the block itll come out of it. YES my driving is very hard the car had 1200 miles on these bearings and maybe 300 of them are normal driving the rest is spirited driving around town, highway pulls, the strip,and drifting but even if the engine were driven at redline the entire 1200 miles the bearings should be able to handle it. the pump IS a 7mge pump and my cooler relief spring has a crack in it. i've found several things contributing to this problem. last time i just thought i was unlucky and got a bad bearing so i dropped the pan and put some bearings in it. this time i dropped the engine and put it on the stand so i'm finding the things to can't see until they come apart /: Oh well if it throws another rod then this block will go to the scrap bin I have the 185 plus parts now but i dont have the 335 plus for another swap at the moment.
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
turbonicsperformance is offline   Reply With Quote
