Old 10-07-2005, 09:38 PM   #3
joel w
joel w's Avatar
[QUOTE=smurfmods]Not sure what a VAC selenoid is... may not have them. Is that going to make a difference? Do I have to have them?
ya my bad, i misread you, it sounds like its complete setup. may have to open it to determin what wires do what? got to be some info on net somewhere? where did you get it?
i found this for an hks fuzzy controller? give you some idea
Install
•12-volt ignition power
•Chassis ground
•Input vacuum line from pressurized side of turbo to port 2 on stepping motor
•Output vacuum line from port 3 on stepping motor to wastegate
•Manifold pressure vacuum reference from intake manifold to port 1 on stepping motor
•Only the EVC Pro will require these additional wires to be run to the ECU:
•Speed sensor signal
•Tachometer rpm signal
•Throttle position signal
yours is probably similar but cant help much more,, here is that page i was looking at http://www.superstreetonline.com/tec...83/index4.html
