Old 11-12-2011, 05:03 AM   #2
Turboron_99
Turboron_99's Avatar
Turboron_99 is on a distinguished road
Thanks for the reply,
Today did a compression check on the car, looked really good, the biggest percent difference i had was 3 percent and it was between cyclinders 3 and 6.
I did do a acidity test on the coolant came back fine, also the Coolant is still bright orange, I see no muddy looking coolant.
I took the car out and drove it around and everything was fine, I am going to assume that it was a air bubble trapped in the coolant system somewhere.
Plans for Saturday, is a oil change and I am going to tear about the intercooler setup, as you can clearly see that there has been blow by at some time from the valve covers and it got blown all into the intercooler piping. I am going to setup a catch can so i only have to clean it out once!
Are there any other things i should do or look at?
Turboron_99 is offline   Reply With Quote
