Old 11-06-2011, 01:26 AM   #1
Sonyps307
I have the gte oil filter/cooler feeder but I seen on other post you saying that set up sucks. So You think I should get one of the kits that relocates the filter then goes out to feed the cooler. What do you think about the turbo oil drain. maybe I can have a drain fitting welded higher in the side of the pan
