Old 10-25-2011, 12:08 AM   #1
Strut bars don't do much for the MKIII, really... You'll be better off investing in a stiffer sway bar and replacing all the worn out bushings.
If twist is an issue and it's not a hard top welding in an X brace under the targa top (to essentially make it a extra rigid T-top) and adding more bracing underneath the car in the center may help significantly.
