Old 10-22-2011, 04:22 AM   #2
87hilux7mge
87hilux7mge's Avatar
ferrea valves are really good.
if you want a cheap, effective solution, just disassemble the head (you will need a valve spring compressor, large C-clamp type.) label all the valves, springs, retainers, lifter buckets, shims and keepers in ziplock bags, then polish the valves and lap them yourself (several online tutorials for this, just check to make sure the valves dont have excessive play in the valve guides.)
i saved a good 300 bux doing my own, and all my valves hold 20+inches of vacuum.
u can also do a valve spring upgrade by getting the BBC inner springs from comp cams and install them instead of stock ones. more seat pressure and its about 60 bux for 24 of them (they are sold in sets of 12, hm, wonder why....?)
i have a buddy with some ferrea valves in his 7m head, and they look titties tho.
