Old 10-09-2011, 03:54 PM   #1
carl johansson
carl johansson is on a distinguished road
check your belts, hopefully one is slipping! other stuff would be alot more expensive to fix. To diagnose you could spray all of the belts with belt dressing - if it stops squealing - either a belt is loose, or is worn out!
since you are having some iddue with power steering - i guess thats where i would start - the belt that runs the power steering pump
Carl Johansson
carl johansson is offline   Reply With Quote
