Old 10-03-2011, 02:00 AM   #1
87hilux7mge
87hilux7mge's Avatar
looks like 2-3 degrees is stock uncancled is stock. so as long as its not bent way outta wack, you should be fine.
just check both output and pinion angles and if its not over a couple degrees you should be fine. just be aware that youll get more vibrations through a fully solid shaft. (lemons car, gotta be comfy! haha)
