Thread: Ffim
Old 09-27-2011, 03:29 PM   #1
turbonicsperformance
turbonicsperformance is on a distinguished road
you have to get a 1jz and a 7m manifold cut both manifolds at the runners and weld the 7m runners to the 1j plenum. you have to lower the alternator in order to run it though.
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
turbonicsperformance is offline   Reply With Quote
