Old 09-26-2011, 01:07 PM   #3
El Supracabras
El Supracabras's Avatar
Originally Posted by Nitetrpr View Post
Thank you If I were to use the housing what injectors would I need and would anything else need to be changed? What is the outcome more HP?
The outcome would be you could run more boost before hitting fuel cut. If you have it tuned properly, yes, the extra boost will yield extra HP. The correct injector size needed would be 560cc. 550 is more commonly available and close enough.
This is not a "slap it on and crank the boost" mod. Fuel pressure, AFM bypass screw and injector size all need to be adjusted for this to be an actual "upgrade". If you're not ready to get the injectors and everything else, don't use the housing.
