Old 09-14-2011, 04:48 AM   #1
Jrsinnovations
Jrsinnovations is on a distinguished road
Exclamation
Okay so I hav checked the grounds and they appear to be good I have checked them to be sure tho. How ever I did manage to get the car started with a can of starter fluid. Now I checked the fuel pump relay resistor and if I'm not mistaken it shouldn't read more than .7 ohms if it's good. But my is reading 1.1 ohms. I did order a replacement. Should this be the problem to not starting the car? I did narrow it down to a fuel issue but is the relay resistor the only problem? I would grateful appreciate your help and input in regards to this matter thank you in advance.
Can anyone please inform me on how to check the fuel pump with out dropping the tank and removing the fuel pump
Thank you
Jrsinnovations is offline   Reply With Quote
