save my supra!
apparently me and this 97 j-spec RH n/a supra are accident prone >.< everything i touch breaks and its always parts where i can't find the parts anywhere so i need some help from the mkIV world. hook me up with links or people that can help me out. here's the list.
rear wheel bearings
rear seal on the transmission( right before the connector to the driveshaft)
fan blade/shroud
passenger side mirror assembly
the plastic trim for the drivers side exterior bottom panel
antenna
the wire that is thread around the pulley from the little motor to the window in the d side door( snapped last week window is held up with amp wire -.-)
here's the hard one that ive been looking for for 3 months ....
okay so i lost the key to my car ( the only F*%#$ng one)... and my lt. col. told me i HAD to move my car that instant. so... i took a screw driver to the ignition. okay on the steering wheel i took the plastic peices that go around the turn signal/ windsheild wiper, then dropped the steering column as much as possible and where the key and ignition is put into that soft metal that is factory attached to the steering column with the rounded theft proof bolts? yeah well i chiseled around that round ignition part at the soft metal till i could pull the ignition out and i could start my car with pliers . i know fml before all that i hotwired the car running just to realize that because the ignition part was not turned to on or anything the steering wheel was locked so it was kinda my only choice...... so i need a complete stock steering column with that soft metal part the ignition a key, and preferably two door locks so people will quit stealing my $h1T!!!!!any website links or connections would be so appreciated!!!!!!!!!!!! im desperate.
