Old 09-05-2011, 12:17 AM   #1
btwilson86
Super Moderator
btwilson86's Avatar
ECU tells you right on it which engine and transmission it's for. I think the easiest way to find out which harness you have is to see how many knock sensor connectors you have on it. 1=GE, 2=GTE.
And the KVAFM is important, don't get rid of it unless you're replacing it with some other air metering device (different AFM, MAF, MAP, etc).
