Old 08-27-2011, 01:11 AM   #1
Originally Posted by depami View Post
Are you sure your logic isn't inverted?
Good catch... Just didn't manage to type out what I was thinking. If it IS overheating at highway speeds check the water pump first.
BTW, the temp gauge is logarithmic... 1/4" above center is not the same as 1/8" indicates times 2... it's closer to 1/8" times 3. The red area is so hot that you may be causing engine damage by continuing to operate the vehicle for any period of time.
