Old 08-16-2011, 01:38 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by BradMD View Post
hey just read the thread, im new here and don't know if its too late but is it possible to put the two stock turbos from a 2jz-gte onto a n/a engine, as i have just bought a 94 supra and it would be good if i could do that. So is it possible and what kind of work would need to be done?
Nope, the manifold the oem twins mount on doesn't fit the 2jz-ge head. In theory I guess it's possible with a ton of custom fab work (weeks and weeks, and thousands of dollars - really!), but it definitely isn't practical.
Your only practical options are:
1) Sell your n/a and get a true Mkiv TT (this is by far your best option, since you get all the braking power, suspension, and bulletproof drivetrain of the TT - not just the turbos).
2) Put a complete n/a-T kit on your n/a (which upgrades your turbos, your fuel system, head gasket, head studs, and your ignition). After that, you'll have to figure out how to upgrade your braking system (calipers&rotors, bmc, abs system, etc), suspension, transmission and and differential...when all priced out with labor will cost you more than the difference between a used TT and a used n/a.
Life begins at 30psi.
