Old 08-12-2011, 10:28 PM   #1
907mge
907mge's Avatar
As long as you have the moly lube you should be fine with 75. I know when I put in the studs it was 90. But if you are using motor oil the torque spec is higher I believe. But if you are still not sure then you can always call ARP and ask for the spec.
