Thread: MAFT questions?
Old 08-11-2011, 07:22 AM   #1
The original MAF Translator and the MAFT Gen II only support MAF conversions; No S/D or solo MAP setups. That said, there's a lot to be said for the GM MAF... They're still a much preferred meter for upgraded setups. The KVAFM is an EXCELLENT meter but the minute you want something a good deal larger or want to run blow-through, you're screwed (You can run a MAF in a blow-through setup with little difficulty).
